iphone 3gs problem
10 Aug 2003
London
After having changed a cracked screen on a iphone 3gs.. i am experiencing a problem wherethe ear speaker will not work, but the handsfree/speaker will work.
I am guessing tha the flex cable (cable no3) or the connector itself (maybe 1 or 2 pins broke when taking out or inserting the cable) - that is damaged.. is there any easy way to tell which is it that needs replacing (the flex cable or the connector itself)?
Thanks in advance guys
Just buy a flex cable for peanuts on the bay, mine had a very small scracth on the flex itself, turned out to be the issue and a new one fixed it.
