- 10 Jun 2010
- Scotland
Been playing with the new iPhone 4s today. Took a video with it... only to discover it was no where near 1080p.
It was actually.
General
Complete name : D:\My Pictures\IMG_0012.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 403 KiB
Duration : 4s 179ms
Overall bit rate : 790 Kbps
Recorded date : 2011-11-04T00:26:55+0000
Encoded date : UTC 2011-11-04 00:34:38
Tagged date : UTC 2011-11-04 00:34:40
Writing application : 5.0
Writing library : Apple QuickTime
Make : Apple
©xyz : +55.6540-004.6848+018.000/
Model : iPhone 4S
com.apple.quicktime.make : Apple
com.apple.quicktime.creationdate : 2011-11-04T00:26:55+0000
com.apple.quicktime.location.ISO : +55.6540-004.6848+018.000/
com.apple.quicktime.software : 5.0
com.apple.quicktime.model : iPhone 4S
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4s 167ms
Bit rate mode : Variable
Bit rate : 722 Kbps
Width : 568 pixels
Height : 320 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.132
Stream size : 367 KiB (91%)
Title : Core Media Video
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 4s 179ms
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 32.4 KiB (8%)
Title : Core Media Audio
Have I missed something totally obvious? Is there a setting to up the res?
It was actually.
General
Format : MPEG-4
Codec ID : qt
File size : 403 KiB
Duration : 4s 179ms
Make : Apple
Model : iPhone 4S
Video
Format : AVC
Codec ID : avc1
Duration : 4s 167ms
Bit rate : 722 Kbps
Width : 568 pixels
Height : 320 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 4s 179ms
