iphone 4s keeps disconnecting?
18 Oct 2002
Behind you... Naked!
I have robbed my daughters old iphone 4s - It will be great to use in my wifes radio in teh kitchen to replace the aging ipod in the dock.
Now, every time I try to connect it to the wifes laptop, it constantly connects and disconnects all the time... in a permanent on..Off...On..Off... abotu 2 times a second non stop.
@It does not do this on my PC or my laptops, only hers... I am NOT willing to have itunes on my stuff, so before you go there... lets not.
Is there any known reson for this?
Thanks!
No, thats not possible.
As I said, it does not have an issue when I connect it to my computers and I do not have itunes on it.
It does have this issue on my wifes Laptop and she does have it.
I also might take this opportunity to also say that she uses Itunes for her ipod and the ipod has no issues... Its the 4S that connects and disconnects all the time.
Also, FWIW, her Laptop has both USB 2 and USB3 ports and it makes no difference what ports I try, so it surely cannot be the USB drivers either?
NO NO NO NO
I said that her computer that does have itunes is the one that cannot connect to it.
Mine that does NOT have itunes all connect just fine.
Rstore it?
Ok, I will have to now put itunes onto my PC then wont I?
