iphone 4s questions
4 Dec 2002
Bourne, Lincs
Looking at getting the 4S on 02.
can you tether with it?
any way to import text messages from android?
I use an app on my droid to show what wireless networks are around includibg signal strength channel i know there was an app like this years ago bu it was pulled
thanks
kimbie
You can tether as long as your data plan allows this. I believe all new O2 data plans allow this but with older ones you will need to pay extra.
I don't know of any way to import texts.
The wifi part of settings will show you what wifi networks are available nearby.
@mrochester - Thanks for the reply, settings only shows your what networks are nearby, at work we will use multiple APs in a site, and it is handy to see all of the APs and if any other WiFi networks are sat on the same channels.
@Scuzzy - Thanks for that I will take a look, anything free like that?
