Does your iPhone rattle when shaken?
Not on this, but mine rattles when the vibration goes off - a brief check inside narrows the culprit to the new circular vibration motor located near the SIM card slot...
Please do not hotlink images. Thank you.
When this vibrates, it has what sounds like a loose part inside that is being pinged around. It sounds very cheap and not at all like other iPhone 4 (drum vibration motor accepted) or other iPhone 4S'.
Apple are collecting it on Tuesday for a replacement/repair inside of 5 days. Will see what happens next!
