Iphone 5 charger
24 Jan 2009
Edinburgh
I've went through 3 chargers recently for my Iphone, every single one keeps going faulty at the connection where it plugs into the phone.
Anyone purchased a charger that seems well made?
It's a very common problem even with the official Apple cables, I've been through 5 now for the iPad, I just tend to buy cheap knockoffs now from Ebay for a quid each and keep a stock of them.
I found the cheap cables was pretty crap but haven't had any problems with the apple ones.
Hmm, not had any problems with mine. Depends if you unplug it by pulling on the cable or the connector I guess...
Problem with the cheapo 3rd party cables is that they don't seem to be supported on iOS7 now.
Remember apple warranty your cables for 2 years if it goes faulty take it into your local apple store and they will sort you out
Braided lightening cable ...... Tell me more
Not had a problem with the one I got for my ipad, which I use for my iphone too.. Thou I'm still using the OG cable I got from my iPod nano when they first came out.
I've braided the two cables together myself using some cable tidy from maplins.. And they have taken a battering.
