Hello All,
If this is in the wrong section then I'm sorry just couldn't find anywhere else to put it.
I have I IPhone 5.
My son plays angry birds transformers on it and after the last two IOS updates (on 9.3.5 now) when the events start it doesn't seem to count down correctly so example is this.
in the game you get events to unlock new characters now once you have done all 4 levels you have to wait 45 mins to an hour for it to refill so at this point I press the home button and leave it. now when its re opened the timer doesn't go down and says 45 mins still or it does go down and then jumps back up to the time left when I pressed the home button.
If I close the game and re open it then it refreshes correctly till you come off the game and it does the same thing again resulting in you needing to restart the game again.
It never used to do this till I installed the IOS update (not 9.3.5 but one before that). has anyone else came across this issue or know how to fix it? google has no results on the issue.
any help would be grateful as this issue is annoying considering this game is all based on real time passing by correctly (events, character upgrades etc)
I have I IPhone 5.
