Iphone 7 plus Jailbreak
Si.
Si.
22 Oct 2002
Melbourne, Aus
Hi All,
I understand from the sticky that Jailbreaking is allowed to be discussed, if this isn't the case please delete this with my apologies.
I want to download and install Carbridge but need a Jailbroken phone to do it.. what's the best way to jailbreak an iPhone 7 plus.. and other that breaking the warranty, is it safe?
How many here have done it?
Never owned an iPhone but you would download the software to your PC, connect your phone to the PC via the usb cable, then click a few buttons on the PC software. That would be it pretty much.
You'll want to check your iOS version is compatible with the latest jailbreak method - it can be a bit of a minefield (lots of fake sites), so if you want, list it here, and I'll do some digging :-)
Thanks, I'm running 12.1.4 (I know, latest version so that makes it a little harder)
As above, but to be honest, it really isn't worth the hassle - Apple get really funny if they find out you've jailbroken, even if you're trying to fix it out of warranty
