Hi, my son needs a new screen for his iphone7.
Can I buy a new screen with everything attached without the need to move over parts from damaged screen?
(Any links to new screen would be appreciated)
Thank you.
Short answer is no. The home button and top camera will need swapping over. The 7's home button is tied to the board and allows for touchID. I do quite a lot of these and the process to swap the parts over is not a difficult process. All fiddly and tiny but not difficult.
OK Thank you for the quick reply.
Should this one do the job
https://www.amazon.co.uk/AG-Neovo-Screen-Replacement-Display/dp/B07KWVG19J/ref=sr_1_10?crid=2LIUFXJHLY2B&keywords=iphone+7+screen+replacement&qid=1563192575&s=gateway&sprefix=iphone+7+scree,aps,183&sr=8-10
I've changed a few iPhone 4 and iPhone 6 screens before for my boys but not the iPhone 7.
Thank you.
Yea they are fine, slightly duller than the OE screen but turn the brightness up a tad and they are perfectly fine.
