iPhone auto brightness
10 Nov 2006
I’m a recent convert from android and have had my iPhone for a few weeks now. What is the deal with auto brightness? It straight up does not work. If I go into settings and switch it off and back on then it auto adjusts to the environment once but then doesn’t at any time after that.
What am I missing here?
You must have something set wrong because I’ve found it works and works really quickly. I don’t even know where the settings are because I’ve never even been into them.
Hopefully someone can point you at the right place to check.
Nor I, must be a setting someplace.
Make sure True Tone is on. I take it, it’s that that you’re flicking on and off?
Maybe something is covering the sensor at the front like a silly screen protector or case.
True Tone is on but that’s not what I was flicking on and off. There’s an auto brightness setting in accessibility>display and text size. I’m not sure what the difference is to be honest.
No screen protector and official Apple case so I don’t think it’s that.
Reassuring to know it’s probably a setting but still unsure what it could be. Maybe I’ll nip to the Apple Store tomorrow to see if I can get it sorted. It’s almost certainly something embarrassingly straight forward.
I’ll be interested to know what it is once you find it. I seem to remember something back from the very early days about calibrating it in a dark room but I don’t recall the details and I’ve never done it.
The auto brightness should respond really quickly. I use my phone in the car with PocketGPSWorld so it’s always on and at nighttime, if I flick the interior light on, the phone brightens up very quickly and then goes down again when I turn the light off. It’s very noticeable.
Finally got around to taking it into the Apple Store. They couldn’t definitively say what was causing this but a hard reset of the phone seems to have fixed it.
Only thing I’m still confused by is that auto-brightness disengages once I manually change the brightness which makes sense but I would expect it turn back on once I lock the screen which it doesn’t. Only way of turning it back on is to switch it off and on again.
