iPhone Data Disabling help!
26 Jan 2003
Nottm
Hello all,
I'm going on holiday to Mexico on Thursday and I need to disable any data usage so I don't get charged an extortionate amount of money on my contract for roaming.
How can I ensure that I do this successfully?
Cheers...
Just use the option: Settings --> General --> Network --> Data Roaming (set to off)
Worked a treat when I was abroad last month. I reset the data counter before I went and it didn't move from zero
As above - this is included as a feature to stop you running up large bills.
If you want to disable it in the UK without jailbreaking, you can just mis-spell your EDGE settings. add a - to the end of the APN or something.
Don't forget to set the mail checker to "Manual"
Just incase you forget / don't set the data roaming to off.
