iPhone Explorer
31 Jan 2007
Hey,
I downloaded iPhone Explorer from Macroplant ages ago as it claims I can just open it up and drag and drop the apps folders into a folder on my pc in order to backup my data from each one.
When i open the program, I can see all the folders per app and can click and drag them, when i drag them over a window on my pc and let go, I get a very fast glimpse of a file transfer dialog and then nothing. No files/folders look to have transferred at all.
I have contacted Macroplant support 3 times about this issue to no avail.
All I want to do is to be able to backup data files from my apps on my iPhone to my PC, per application.
Any ideas, have any of you guys got this program to work successfully?
My system is running Win 7 Pro 64 bit.
Thanks
Neil
Just tried iFunBox.
I can't seem to find the list of app data folders with iFunBox.
iPhone Explorer shows them all instantly but they are nowhere to be seen using ifunbox.
I also have NO wish in jailbreaking my device
Any ideas?
