Iphone external storage device
23 May 2006
Is it possible to have an external storage device for an Iphone 5 which will allow films and music to be streamed off it and could anyone recommend one.
Will the default apps work for playing films / music or do you need a separate app.
I know Apple like to restrict what people can/can't do on their phones hence why i'm asking if its possible
Thanks
Thanks Crumplypork, I had a look at the morphie but I found something else which is more suitable, Its called RAVpower hub which you can use to stream content to and from to more than one phone or ipad using wifi. This will be good when travelling
