iphone in bangkok
19 Oct 2002
Belgium
Hi,
We (my fiancé and I) are going on our honeymoon trip to Thailand in November this year.
And we both like the IPhone ;)
Question : will the Apple IPhone will be (much) cheaper in Bangkok and foremost will we be able to use it here in Belgium??
Sorry I can't remember the dominant technology in Thailand but in asia pac it tends to be GSM or T/CDMA IIRC.
Check carefully the network technology. If you're using back here then GSM tri/quad band should be ok. Just check it's not TDMA or CDMA.
Then you have to ensure that it can run with another operator's SIM card (ie BASE or Proximus etc in Belgium).
Yup, but I heard that the Iphoned would be launched in December here in Europe, so I thought that with a little chance it will be launched by november in Thailand :)
thx for the reactions
El jobso said movies would be in europe spring 2007. I don't see that happening. Don't hold your breath on the iPhone
