iPhone Installer problem.
Caporegime
4 Jul 2004
Hey.
I've jailbroke my iPhone to 1.1.3 and I have had to uninstall all my apps, to reinstall them again as they were not showing on the home screen anymore. Summerboard will not uninstall though and shows this message "Main script execution failed!".
How am I meant to uninstall it now?
Thanks.
Righto, so, next you'll need to use a visual SSH client (WinSCP I believe is one) and navigate to your Summerboard folders and delete them.
The ones I can find on my touch, are;
Code:
/Var/root/Library/SummerBoard
/Library/Frameworks/SummerBoard.framework
EDIT: How do I get SSH? (I can't find it in the installer) :p
It's under System in the Installer list, you may need the community sources to see it.
Similar problem to what I was having, ended up restoring back to 1.1.2.
I couldn't SSH into my phone for the life of me, just wouldn't work.
SSH wont show on the home screen under 1.1.3 but its there and should work.....
Still no chance im going 1.1.3 until they get the iron out !!
