iPhone Maps.
17 Dec 2009
Wales
Now then, I am looking at iPhone 4 contracts and good Maps software is something I'm after, is it worth paying the extra for say Orange maps or are there good free alternatives on the app store?
What do you want from the map?
Built in map is ok, but its just google maps on your phone.
If you want navigation, look at Tom-Tom, Navigong or Co-pilot.
As above, really. For day to day use, what's the normal iPhone maps app missing that you're after? If you're after something for SatNav, then I've seen co-pilot working nicely, though I don't have it myself.
Wasn't aware there was built in maps,will be using it quite frequently to walk to new destinations in areas I don't know, sounds like google maps will easily suffice for this.
Thanks for the reply's :)
