2) This hidden file is neither new nor secret.
It’s just moved. Location services have been available to the Apple device for some time. Understand what this file is – a log generated by the various radios and sensors located within the device. This file is utilized by several operations on the device that actually is what makes this device pretty “smart”. This file existed in a different form prior to iOS 4, but not in form it is today.
Currently, consolidated.db lies within the “User Data Partition” on the device. This is a logical filesystem that maintains non-system level privileges and where most of the data is stored. When you perform an iOS Backup through iTunes, it is backing up this partition. Prior to iOS 4, a file called h-cells.plist actually existed in the /root/Library/caches/locationd folder, but with hidden access from other software and applications. h-cells.plist contained much of the same information regarding baseband radio locations as consolidated.db does now, but in Apple Property List format rather than sqlite3. Through my work with various law enforcement agencies, we’ve used h-cells.plist on devices older than iOS 4 to harvest geolocational evidence from iOS devices.
So lets recap.
h-cells.plist = Pre iOS 4 / Radio Logs including Geolocational Data / Hidden from Forensic Extraction (usually)
consolidated.db = iOS 4+ / Radio logs including geolocational Data / Easily acquired through simple forensic techniques
The change comes with a feature introduced in iOS 4 – Mutlitasking and Background Location Services. Apps now have to use Apple’s API to operate in the background – remember, this is not pure unix we’re dealing with – it is only a logical multitasking through Apple’s API. Because of these new APIs and the sandbox design of 3rd party applications, Apple had to move access to this data. Either way, it is not secret, malicious, or hidden. Users still have to approve location access to any application and have the ability to instantly turn off location services to applications inside the Settings menu on their device. That does not stop the generation of these logs, however, it simply prevents applications from utilizing the APIs to access the data.
