iPhone to Exchange - Quick question
12 Jun 2012
West Yorkshire
Guys.
From previous threads i have set up a iPhone on our exchange, although a few days before he needed his contacts before email so i sync'd them with iTunes.
Question is: Now its time to put the full sync with Exchange, im not going to get double everyones contacts am i? or will they let me replace?
Thanks.
I think you'll get double as thats what happened last time I used iTunes and Exchange. You can untick the Outlook sync in iTunes.
Thanks for that, i thought it would.
Ill unsync with the tick box unticked in itunes then just resync for exchange?
Ta
I think that should do it. it should come up on the phone about what you want to do with the contacts, delete or keep so I'd delete the contacts and let them sync over Exchange.
A backup of the contacts wouldn't hurt though just in case!
