1 Mar 2006 at 19:32 #1 Guv Guv Soldato Joined 24 Oct 2002 Posts 3,257 Location Warwickshire I understand there is something you can now buy that you plug into an ipod and it will add the FM radio feature to the ipod? Anyone got one? Does it work well? thanks
1 Mar 2006 at 20:25 #2 ray ray Associate Joined 18 Oct 2002 Posts 323 Here's a review of one made by Kensington: http://www.ilounge.com/index.php/re...gital-fm-radio-and-transmitter-for-ipod-ipod/
1 Mar 2006 at 20:26 #3 Wyrdo Wyrdo Soldato Joined 19 Feb 2004 Posts 15,102 Location Darlington, UK I'd buy the Apple one but they only do it in white
1 Mar 2006 at 20:45 #4 ray ray Associate Joined 18 Oct 2002 Posts 323 Here's a couple of shootouts between various models from the same site: http://www.ilounge.com/index.php/reviews/comments/the-fall-2005-fm-transmitter-shootout/ http://www.ilounge.com/index.php/re...05-fm-transmitter-shootout-part-2-the-tables/
1 Mar 2006 at 20:48 #5 Rednut05 Rednut05 Suspended Joined 1 Aug 2005 Posts 908 Have have an iTrip. Come in black or white. Plugs into the port on the bottom. Where it connects to the pc. Mine has an LCD Screen on which shows the radio frequency you are sending out. Works well.
1 Mar 2006 at 21:52 #6 Guv Guv Soldato OP Joined 24 Oct 2002 Posts 3,257 Location Warwickshire Rednut05 said: Have have an iTrip. Come in black or white. Plugs into the port on the bottom. Where it connects to the pc. Mine has an LCD Screen on which shows the radio frequency you are sending out. Works well. Click to expand... Do you have a link to a website that sells this? (don't post if it's a competitor) or a model number of the item? thanks
1 Mar 2006 at 22:02 #7 Brum Man Brum Man Soldato Joined 30 Jan 2004 Posts 3,031 Do you mean actually make be able to receive radio signals or enable it to emmit what it is playing as a radio signal?
