Ok, i never use my hold button at the top, and today in car my friend used it while plugged into the car. When i got out i dropped it, now theres a padlock sign and the wheel/buttons don't work, is the padlock a sign for the hold button?
As it dropped it broke the button if thats causing the padlock as i theres a slight orange bit showing and it doesn't slide right across, i mean SLIGHT orange bit very small.
Basically my ipod is finished unless i can sort the button, if thats causing it?
