Is there any way when you download a song from wherever or burn it onto your pc that it can automatically be copied into the itunes file at the same time, so you dont have to add it.
Just it gets a bit annoying clicking "add file" and then going and searching for the song in the file it downloads to, but I dont just want to set the download file as itunes because then that would mean opening itunes every time I wanted to play a song wouldnt it?
I want them to go to two places at the same time and wondered if this was possible?
Thanks
Thanks
