Aii you can use winamp + a plugin.
You could also upgrade the firmware on the iPod to something like Rockbox, which will change the user interface, as well as allowing you to view the contents of the iPod as a removable drive, so you can just drag & drop from Explorer.
Is there any way to convert the files downloaded from itunes to MP3 Files?
I believe you can use Winamp and a few other programs instead of the dreaded iTunes!!!
I'm not sure if that still works
WinAmp won't recognise either of my iPods any more, nor will they show up as removable drives like they used to, only iTunes seems to be able to access them...
http://forums.winamp.com/showthread.php?threadid=279174
edit - Seems you can, but not possible with my touch yet![]()
Why does everyone hate iTunes?![]()
Because it's slow, clunky and the UI is rubbish! I love my iPod, but iTunes is a disgrace of a program. And with the latest version I have to tell iTunes that albums from the same artist should be listed together, not sperately, it's rubbish!
Slow, bloated peice of crap software.
