Ipod reset without mains power
2 May 2003
Hi
I've just loaded the new ipod software update and it now needs to be plugged into the mains to complete the reset. Unfourtunatly I normally charge it of the PC and can't find the mains charger. Is there any way around this? Or am I going to have to buy a new charger?
thanks
It's so it can complete the flash without the risk of it failing due to power loss. I think you can just plug it into a USB port though and it will react the same way.
same thing happened to me with my old 4G...had to borrow a friends mains charger just to connect it to the power once, USB didnt work.
i can see the point of it, as I guess running out of power during a firmware flash could leave you with a paperweight, and potentially cost apple a lot of money in replacements. However the newer ones come without a mains charger, so I assume they can be flashed using usb as a power source from a computer, so it would seem easy to make it the same for the older versions.
well the apples use a firewire > usb on the mains charger right. soo how would it be able to tell the power source :S
