iPod Ripping.
5 Jul 2003
Atlanta, USA
Hi.
Can someone recommend me a iPod ripping software to get music OFF my iPod and onto my computer?
Thanks in advance all. :)
Does the software in these progs, esp sharepod, mean you remove the apple firmware from the ipod or does that stay and can it still be updated as Apple improve the firmware?
look on the link
'With SharePod, nothing needs to be installed on the PC, the program is stored and run from your iPod. All you need to do is plug your iPod into a computer and run SharePod.exe'
Thanks for the tips everyone. :)
Sharepod kept crashing for me.
But Yamipod appears to be working fine at the moment. :)
geeza said:
look on the link
I did see that. "the programme is stored and run from your ipod"...Does that mean the firmware on the ipod is replaced with the third party software???
