iPod shuffle issues
Man of Honour
17 Oct 2002
I'm back baby!
Our lass has bought a second-hand iPod that isn't working properly. Before sending it back I want to make sure a simple update won't fix the problem.
It's a 1Gb shuffle. The little light comes on when it is connected to the lappy via USB, the iPod itself works OK and plays music.
I can't browse it via explorer though it appears in the list of drives with the right name, and I when I try I get an I/O error.
Unfortunately I don't know what iTunes looks like with an iPod attached!
Anything I can do?
It should appear in the Devices menu on the left side of iTunes - that's the only place you can manage the contents from.
It actually isn't picking the iPod up. Edit > Preferences > iPod tab - 'no iPod connected'
iPod completely bust?
I don't know if it's possible with the shuffle, but can you do a reset by holding down the play and centre button? Or does the shuffle even have a centre button?!
There must be a way of resetting it, perhaps the previous owner had it set to Mac configuration and you can't pick it up on a Windows PC or vice versa.
Possibly. The centre buton is a play button on the shuffle, but I'll scout around and see if there's any other way (or, god forbid, refer to the destructions!)
The problem I envisage is that the unit sees it is connected to a USB port (it is charging) but the laptop doesn't see the unit past adding a drive in My Computer.
Warranty information about your iPod
Our records indicate that your product is not covered for service.
The really annoying thing is that it recognises that it is connected to a USB port, and it plays music fine. I just can't get new music on it.
