ipod to standard earphone converter
27 Jul 2005
Norfolk
ok basically earphones that go into the ear are just uncomfortable i must have weird ears or something so can u get ipod to standard earphone's converters and if so where
TY
I dont get what you mean? Do you mean you want a better set of headphones? Ipods use a standard headphone jack, any standard headphones should fit straight into the ipod.
TY
You don't need one, it's a regular 3.5mm headphone jack - any normal headphones you want to put in it will go :)
