ipod touch problem
8 Jan 2008
Eastham/Wirral
Recently I transferred some music from my PC to my ipod touch but instead of just transferring one track I ended up with the lot and some i don't like ..
How do I Delete some music tracks .. Thanks regards Davy:):)
In iTunes with the iPod plugged in, select it and tick the box that 'manually manage music' (Or similar). Then, you can just drag and drop the music you want.
Alternatively, you can select iTunes to only sync selected songs that you want on your iPod. Or another option is to make a playlist with just the music you want.
The best way would be to manually manage your music.
