Ipod touch using Car ipod players
4 Aug 2006
Stevenage , Wisbech
Ok had my ipod touch for a month or so, i love it, just getting a new car on sat and was wondering about replacing the 6 disc multichanger with an iPod friendly car CD player. Now I cant see why it wouldnt, but before i get one will the touch work with the old ipod connections?
Prob a bit of a noob question i know but dont want to waste money on one if it doesnt, even though having it mounted on the dash and connected to the AV inputs would look cooler lol!
It uses the same dock connector but I'm not sure about the compatibility of it all. You will probably have to snoop around the manufacturers website to get your answer.
Totally unrealted but you could get a FM transmitter.
Tune your radio to whatever "unused" FM frequency for the no-wires approach :)
Dont really want to go that way (will do if must though), its not an ideal solution, interference can be a problem in ones ive used before and using ilink is a bit expensive for what it is. Thanks for the advice though, think the only way im gonna be sure is to go into halfords and ask them if i can try it in the ipod enabled stereos. On another note i can get the manufacture Ipod kit for 99 inc fitting but then again theres still no gaurantee it will work.
