Any advice would be great
1) How do you tell when your battery is fully charged - after fully running down, my ipod battery bar is showing full after an hour - but I know this cant be a full charge?
2) Can you randomise a playlist - or a selection (album / artist) or do they have to be played in their listed fashion? The only shuffle I have found randomises all contents rahter than a specific folder etc
3) I have about 100 singles that the ipod / itunes insists on putting in their own (seperate) artist's / album folder - if I create an "album" called singles and manually edit each track will this work? Is there an easier way of doing this? Ie if I have a one hit wonder that says its from album XXXX if I add ";Singles" in Album name will this work?
Cheers
Cheers
