I also use Winamp with the iPod plugin. Its very good I think. Now there are actually two plugins you could use. There is the default MP3 player plugin that Winamp comes with or there is the devoted to iPod plugin at http://www.mlipod.com/. I use this one. When you run the ml_iPod installer it prompts you for permission to remove the Winamp default plugin.Chronicle said:Hi
Can I use an iPod (video ipod) without iTunes?
ATM i use Winamp, i heard there is an ipod plugin for it, if there is is it any good?
Or shall i just use iTunes (don't want to clutter computer with more media players)
Well if you have WinRar or 7Zip or perhaps even WinZip try unpacking the iTunes.exe. There are several files in there and I believe one of them is called AppleSoftwareUpdate which I believe is the program for checking for updates to iTunes and iPods. Take that file out of the iTunes folder, install it and it should function I reckon.Chronicle said:Hmm, would I need iTunes for any updates etc then? Or can you install firmware updates without iTunes?
Also, what sort of videos does it play? Does it play videos in divx by any chance?
(i haven't got the iPod yet, getting it next week)
