In the process of leaning about iRacing and want to get a dedicated graphics card to improve the performance, as apposed to using the on-board one I currently have...
I only want to spend a maximum of £150~
Any suggestions? Would I be better staying with a ASUS / ATI card?
My current spec:
My current spec:
Code:
CPU-Z TXT Report
Binaries
CPU-Z version 1.80.2.x64
Processors
Processors Information
Name AMD A10-5800K
Codename Trinity
Specification AMD A10-5800K APU with Radeon(tm) HD Graphics
Package Socket FM2 (904)
CPUID F.0.1
Extended CPUID 15.10
Core Stepping TN-A1
Technology 32 nm
TDP Limit 99.8 Watts
Core Speed 4320.5 MHz
Multiplier x Bus Speed 43.0 x 100.5 MHz
Stock frequency 4300 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FM
Chipset
Northbridge AMD K15 IMC rev. 00
Southbridge AMD A88X FCH rev. 2.6
Graphic Interface PCI-Express
PCI-E Link Width x0
PCI-E Max Link Width x0
Memory Type DDR3
Memory Size 16 GBytes
Channels Dual
Memory Frequency 669.9 MHz (3:20)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 10
Cycle Time (tRAS) 24
Bank Cycle Time (tRC) 33
Uncore Frequency 1808.6 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Team Group Inc. (7F7F7F7FEF000000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number Vulcan-2400
Manufacturing date Week 07/Year 14
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.3
AMP no
Monitoring
Mainboard Model A88XM-PLUS (0x000002C7 - 0x14281C38)
Graphics
Number of adapters 1
Display Adapters
Display adapter 0
ID 0x20D0004
Name AMD Radeon HD 7660D
Board Manufacturer ASUSTeK Computer Inc.
Codename Devastator
Memory size 768 MB
PCI device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Vendor ID 0x1002 (0x1043)
Model ID 0x9901 (0x8526)
Performance Level 0
Core clock 950.0 MHz
Memory clock 667.0 MHz
Performance Level 1
