iracing newb
27 Aug 2014
hi all newb here
just starting out with iracing probably should have asked this before i bought a pc lol but hey ho i just bought this what are your thoughts will it run ok
AMD Richland 6600k Quad Core Processor / CPU running at 3.9GHz (With 4.2GHz Turbo Mode)
8GB DDR3 1600MHZ RAM
2gb Nvidia Geforce GTX 750TI GRAPHICS
1000GB 7200RPM SATA Hard Drive
CD / DVD-RW Dual Layer Optical Disc Drive
FM2+ MICRO ATX Motherboard
500W Quiet Power Supply Featuring Large 120mm Cooling Fan
High Quality Desktop PC Gaming Case.
Gigabit Ethernet 10/100/1000 Mbps LAN
6 X High Speed USB 2.0 Ports
6 Channel HD Audio
4 X SATA II 3GB/s Ports
1 X PCI Express X16 Slot
1 X PCI- Slot
2 X PS/2 Port (For Keyboard / Mouse)
1 X VGA Port
1 X Dvi Port
1 X Hdmi Port
Triple Monitor Support
Wireless Keyboard & Mouse
unless it has changed recently iRacing is an incredibly undemanding game graphics wise, you can probably max the game out with that computer.
Do you have a wheel, or at least a gamepad of some sort you can use with your computer? I haven't tried iRacing, but pretty much all simulators benefit hugely from a wheel.
