IRC Help
17 Mar 2005
Home
I need a bot that can do this
!Find <file>
bot returns Bot> I found file on www.something.com\file.exe
I dont want a google bot i want it to search a default site that i can set.
Ive looked through loads of guides and other sites just baffels me could anyone help ?
You want a whole bot or a script?
In eggdrop which uses TCL I used to following:
Code:
package require http
set agent "Mozilla/4.75 (X11; U; Linux 2.2.17; i586; Nav)"
bind pub - !search public:search
proc public:search {nick host hand chan text} {
	global agent all
	set url "http://www.something.com/search.php?=[lindex $text 0]"
	set http [::http::config -useragent $agent]
	set http [::http::geturl $url]
	set html [::http::data $http]
	regsub -all "\n" $html "" html
	regsub -all "members and" $html "" html
	regexp {<b>(.*?)</b>} $html - all
	putserv "PRIVMSG $chan :$active"
I haven't coded tcl in a while, but that should work, providing you have the search page. The first result would be inbetween the <b> tags.
But you need to supply a bit more information on what you need :)
i just want to have a seperate iRC running with the bot on im guessing i just need the full script so that itll all work.
You'll need a socket bot for that.
Head over to mircscripts.org and ask for some help in their forums, or check the download section, there might be one there.
I'd write you a bot, but i suck with everything socket related. :(
