IRQL NOT LESS OR EQUAL Bsod in Vista 64bit on Network Transfer
9 Aug 2003
Liverpool
I've recently updated my main rig (Which is an Opteron 165, 2GB PC3200 RAM, DFI LanParty UT4, Radeon X1800XT) with Vista Ultimate 64Bit edition. It's all running smoothly except when I've been trying to transfer files from my this system onto m Shuttle PC I get a IRQL NOT LESS OR EQUAL BSDO. However, this is what's bugging me, it can do a file transfer no problem if I leave the system alone (the one crashing that is), but if I try and say watch a video, or browse with a few tabs open it BSOD on me. Any ideas?
when your PC boots up check the IRQ listings. you may have Ethernet plus IDE Plus PCI on the same IRQ, if so disable them one at a time and then re-enable them and hopefully it will re-assign them to different IRQ's and hopefully resolve your problem!
