irql_not_less_or_equal bluescreen after uninstalling kaspersky av 2009
4 Jan 2004
¯\_(ツ)_/¯
Now I can only boot intO safe mode. This is with windows xp pro sp3...
Has anyone else had this problem and if so how did yOu fix it?
If I recall correctly when I had that blue screen, I had to boot into Recovery Console and then run "fixboot" and "fixmbr".
This wasn't down to Kaspersky in my case though, so this might not help.
It probably borked a system file on its way out. When removing AVs I always try to use the removal tool if one exists. The uninstallers are usually crap.
