I've been getting this BSOD for the last 2 years, and have only just solved the problem....1 faulty RAM module (out of two). I had to run memtest for an hour to get the error to show though.
This is most likely to be either a RAM problem or a driver issue; I'd put my bet on the RAM. Can we have some more info about your rig?
directly it is yes. but the likelyhood is the driver is fine, and is simply addressing nasty memory.
EDIT: G|mp, just to add to that, you'll know whether it's a specific driver/device or something more general (ie. memory) that's causing the problem by which files are indicated to have supposedly caused the BSOD.
For example, when I was mistakenly undervolting my vid card, I kept getting BSODs pointing to nvdisp.dll --> graphics card driver. Every single one pointed to this file, (some of which were IRQL_NOT_LESS_OR_EQUAL BSODs). However, when my RAM packed in recently, I was getting BSODs pointing to all sorts of things...usbport.sys, nv[something[.dll, etc. This suggested that there was something more widespread than specific device incompatibilities causing the BSODs. Nevertheless, these things have a habit of breaking trends sometimes...
