i have not looked to see if there is anything available, but i have 2 22" led 1080 monitors, no 120hz and beyond stuff and once i sort out driver issues i will try my first hand at proper dual monitor setup and see what movies and games are like and so if i like it and want to keep it that way for the most part then when i eventually upgrade gpu i will look at a 3rd monitor.
problem is my desk while fairly large is not big enough for 3 22" monitors nor do i have the room space to expand and without going for a too much of a triangle layout i was thinking of a smaller screen for the centre, but obviously 1080.
that leads to the question, if you can get 1080 monitors smaller than 20/19" will the quality be the same when it comes to setting up or will you notice the size difference?
cheers for reading and any replies
