- 4 Dec 2009
- Worcestershire
As the title says, is 21.2dBA loud for a case fan?
Thanks
Thanks
Under 1000RPM normally equates to a quiet fan in my subjective opinion.
Thanks
Thanks for the replies, and I bought the fan in the end. It was this one.Which fan is it?
I find RPM to be a more accurate figure for the amount of noise you can expect from a fan than the manufacturer's dBA figures, which seem to be essentially made up for the most part. Under 1000RPM normally equates to a quiet fan in my subjective opinion.
