is 600w enough?
30 Nov 2005
q9550 @3.8ghz 1.2vcore in windows 1.41 in bios
4gb ram
x-fi
2* sata II
1 dvdrw
1* firewire card
1* wifi card
on a s seasonic 600w s12
can i add a Point of View GeForce GTX 280 1024MB to the mix ?
Seasonic make quality psus, it should cope fine unless you've had it for 5 years, you might need a 2x6pin -> 8pin converter.
Yip! I would say so.
Im using a Corsair 550W with Q9550 @ 3.4Ghz, 4GB RAM, 2 x DVDRW, 1 x Velociraptor, 2 x 7200 RPM HD's, 4870 512MB, XFi, 4 fans, Mem card reader and case light. I think thats everything and it works totally fine.
