is 750w enough for sli 970's
Easily
At load a single-970 system with an i7-4960X @ 4.2GHz (hungrier than your 4790) will draw around 300W from the socket.
Reference:
http://www.anandtech.com/show/8568/the-geforce-gtx-970-review-feat-evga/15
Even if we assume that the 970 draws ALL of that, and that the PSU is 100% efficient (PSU's are measured in output, not what they pull from the socket) you'd be just about safe with 600W. 750W would give you 25% extra over that for accessories, extra disk drives and a decent chunk of capacitor degradation
In reality, an i7/SLI 970 system will draw significantly less than 600W from the wall, and even with heavy overclocking and excellent cooling (as the 970 seems to be TDP limited in most overclocks) you're well within a safe margin with a 750W. Unless you went crazy with the overclocks, I'd be comfortable with 650W for an SLI970 setup.
Yeah you should be fine. I used a XFX 850w black edition (OEM by seasonic) with CF GTX 970 HOF and i7 5820K @ 4.5Ghz without any problem. The only reason made me buy another superflower 1000w platinum was because of the white colour scheme. :D
