would it actually bottleneck me to have so much?
64 bit can handle way more than 8gb ,the sky's the limit![]()
yeah it will be a massive bottleneck
best to stick to 256mb tbh.
Actually 4gb might be a bottleneck.
EVGA's 680i has a horrible memory controller - 2gb is fine for 1066mhz+ but as soon as you add 4gb and fill the dimms slots, it's crippled to a maximum of 800mhz!
) so i'd want as much ram as i could lay my hands on... but most people won't ever need that much ram it really does depend what your doing with your pc....Actually 4gb might be a bottleneck.
EVGA's 680i has a horrible memory controller - 2gb is fine for 1066mhz+ but as soon as you add 4gb and fill the dimms slots, it's crippled to a maximum of 800mhz! if you try to push it any faster it will become very unstable and cause many memory/paging errors.
Is 8gb overkill? Depends on what you use your computer for
I'd highly recommend it if youre doing anything with Video editing or 3D rendering. Just make double sure that the applications youre planning to use support 8gb. e.g Photoshop still cant make use of more than 4gb, regardless of the OS.
I wouldn't bother by the time the apps to use it are out we'll be DDR 10 or 15
