is 900 DPI considered high sensitivity?
16 Nov 2008
West Midlands
I use a razer deathadder at 900 DPI. master sensitivity is at 6.5. X and Y sensitivity are both at 7 im not sure what these are best set too? Windows sensitivity is at 6. Am i considered to be low or high sensitvity gamer?
It's personal preference. Experiment and see what you're comfortable with. Yes, you are a low sensitivity gamer, gaming at 900 dpi. I find the more I meddle with the settings the more frustrated I get. I don't even always bother to install the drivers! :) I happen to have the same mouse, best I've used.
I use mine at 1800DPi sensitivity 3. Just preference after moving up from like a 300 DPi mouse going any higher felt weird. Also i do a lot of 3d modelling where tiny movements are needed so high sensitivity is bad but the higher DPi seems to work better.
