- 28 Jun 2005
- Behind you
in the 80s
I cant do anything about it coz I have cerebral palsy and also cant see very well at all. So to hell to the silly thing, if it blows up, it blows up.
Do you have Coretemp the program?
http://www.thecoolest.zerobrains.com/CoreTemp/
Humor me, run it and report back what the 'Delta to' values are
Re-seat the cooler using the bare minimum of thermal paste.
Bare minimum (rice grain) doesn't work with Qcores Cob
As5 application
http://www.arcticsilver.com/ins_route_step2intelas5.html
I lapped my quad and tower, now the cores have only 1-2 deg difference when fully loaded.
I recommend that you start your OWN thread.
Not very nice to pop in a thread where someone is having heat problems and you come in all smiling about your great clocking quad. A bit selfish tbh.
Hmm, not thread crashing but your first post is all about you and your quad.
Nothing made you reply, also you replied to nothing either so?. All you stated was that your overclock was easy and you want to get your temps even across the 4 cores?. All about you and it belongs in an overclocking/cooling thread other than in a thread when someone is having problems.
Any way. End of subject from me. I'm doing the same to this thread as I'm accusing you off.
