I'm not shocked in the slightest when an enthusiast gets a hold of a severely underclocked 7950.
And it's not just BF3 either:
Tells it's own story, considering the 670 boosted up to 100MHz higher, could be the 7950's higher bandwidth and vram caching doing it's job.
No brainer that you can get a 7950+SSD for the same money as a 670.![]()
I don't get it, that's the first time I have seen a chart that claims a 7950 is better in BF3 than a 670.
http://www.anandtech.com/bench/Product/550?vs=598
this shows a massively different story.
Its always driver/overclock/boost subjective IMO, at least the above comparison is actually showing the boost clocks, many don't.
That 7950 is probably hitting 7970 speeds or more with that OC, so it being level/slightly ahead of the 670 sounds about right.
Overclocks are far from guaranteed, especially a 7950 hitting 1200mhz and a 670 hitting 1300mhz, out of the box, stock clocks the 670 is probably the faster card of the two.
And as this guy says; the 7950 would have been at stock clocks whereas the 670 would already be "boosting".
I really hate being picky but I'm going to be anyway.
In what way does that chart claim that a 7950 is better than a 670.
Out of the 3 metrics (Min/Max/AVG) the 670 wins 2 out of 3, and the margins are so small that personally I would say that in that chart the cards are neck and neck and certainly not that one card is better than the other.
Yes the 7950 and the 670 are very close when both overclocked to near their max, but the 7950 is clearer the better value buy at the moment.
The problem is that most people look up reviews with the 7950 at stock clocks and old drivers, but newer drivers have given large increases for skyrim and BF3 among others.
