Is a CPU cooler necessary for this build?
5 May 2012
Gigabyte Z77-D3H Motherboard Technology
Intel Ivy Bridge I5 3570K Unlocked CPU
1tb Sata Hard Drive
16gb DDR3 1600mhz Memory
Nvidia Geforce GTX 680 2gb GDDR5 with HDMI
Zalman Z11+ Blue LED Gaming Case
24x Dual Layer Sata DVD Writer
750 Watt Branded Power Supply
I am not OC'ing (when I do eventually I will buy a cooler). So do I need a cooler or not? Thanks in advance.
If you are not OC'ing, then assuming you have purchased the retail and not oem version of the cpu you will be fine with the stock hsf. You definitely need a heat sink of some description though, on any build
