may I ask what fans are you using in a pull config? most watercooling fans like the sycthe gentle typhoons work better in push...might help you shave a couple of degrees off
I found in my set up the work better in push but it depends on rad position e.g. Flat/on edge .....like you say it is minimal either way (about 1 degree for me)
