Hey
a while back I purchased the "OcUK Tech Lab - V8 Watercooling Kit 240" to cool my FX 8350.
it does the job but since its been overclocked (4.8) the temps have really increased..... duh
the CPU sits under load high 50deg and can push just over 60.
I was wondering if adding a second rad would be the best solution to reducing the temps.
will the pump be ok to push through the loop with 2 rads? (I assume it will as the kit was sold as being capable to upgrade- but salesmen y'know)
The kit I got is very similar to the one currently on the site if not the same
bought mine early 2014
https://www.overclockers.co.uk/ocuk-tech-labs-v8-watercooling-kit-240-bu-079-tl.html
If you need any more info please let me know
thanks in advance
AMD FX-8350 @4.8
Crosshair V Formula-z
Avexir Raiden 16Gb
Inno 3D 780Ti
thanks in advance
AMD FX-8350 @4.8
Avexir Raiden 16Gb
Inno 3D 780Ti
