is a VCD region coded ?
28 Jul 2004
llanelli , south wales
wasn't sure where to put this question so thought i'd try here
i'm after michael jacksons "ghosts" but atm the only version in the uk is vhs .... and the best i can see is vcd available on amazon.com ( us)
so if i purchased this wil i be able to play it here ? is it region locked ?
any help would be appreciated
google search says
VCDs are region code free
VCDs are region code free, so there is no restriction on where in the world they will play.
In additon, VCDs can be burned using any one of the three video broadcast standards (NTSC, PAL and SECAM)
so not region locked but can your dvd player play a ntsc video file?
NTSC VCD is 352 x 240, 30 frames/sec PAL VCD is 352 x 288, 25 frames/sec
your probably better off with a video :P unless its SVCD
google search says
i'm more concerned if my pc blu ray player can ....its a sony br .. and doesnt do jack all in terms of recording ... wont even record cd let alone dvd
*EDIT* checked my order hostory with amazon ....it's a :-
Sony BDU-X10S 2x Blu-ray Disc ROM Internal
oh your pc will play it fine , standalone players might have issues outputting it to your tv though as im not sure if our pal TV's can recognise nstc video signals properly
found it :-
PART NUMBER BDU-X10S
DRIVE TYPE Internal Blu-ray Disc BD-ROM Drive
MEDIA & MODES SUPPORTED BD-ROM, BDMV, BDAV, BD-R/RE, DVD-R/-R DL/-RW,
DVD+R/DVD+R DL/+RW,: DVD-ROM, DVD Video , CD-DA,
CD-ROM (XA), CD Extra, Video CD, CD-R/RW, Photo CD,
CD Text, multi-session
found it :-
is VCD
Holy smoke ....nearly £19 to get th evcd from usa ... and thats by snails post ( 21 - 42 business days )
how easy is it to copy over a vhs ? as i'm ordering that instead from uk at just over £8
welll films arrived ...vcd wont play in blu-ray surround system :(
what ripping software is best to convert the vcd to dvd so i can play on my surround system ?
