Is am5 compatible with am4 block
19 Jan 2016
Hi all, is the EK Water Blocks EK-Quantum Velocity² D-RGB CPU Water Block For AMD AM5 - Nickel + Plexi compatible with a am4 cpu? I have checked the hole centres and they are the same, can only see the am5 version on the OcUK website. I am fitting it to an Asus ROG Crosshair VIII Formula board. Thanks.
AM4 and AM5 are the same but it's the backplate you have to be aware on certain motherboards , usually itx boards, but you should be fine.
