I have a ASUS ROG Xonar Phoebus soundcard that I bought about 6 years ago in my current system and am generally pleased with it.
However I am looking to upgrade my computer soon with a ASUS ROG Strix X570-F Gaming motherboard which boasts 'SupremeFX' onboard audio. So now I'm thinking should I scrap my soundcard and just use that instead. Would there be much difference in audio quality?
I listen to music and play games on my PC pretty regularly, but I don't consider myself a particular 'audiophile'. My speakers are Logitech Z906 5.1 Surround Sound connected via three 3.5mm jacks (green, orange, black).
One thing that seems to make a difference is the 'Xear Surround Max' settings in the ROG software (basically virtual surround so that stereo is played on all speakers) and the 'Dolby Home Theatre' software (EQ) included with the card but Im not sure if the motherboard audio supports that or if it would come with something similar/better?
Or should I forget the soundcard/onboard audio idea and just get a DAC instead?
Thanks for any advice!
